06-27-2019 11:35 AM
The CUBE Configuration Guide references a "CUBE Advanced guide":
Note: Licensing implications and configuration details are not covered in this chapter. For information about HA, refer to the High Availability section in the CUBE Advanced guide.
I just can't seem to be able to find this guide. Can somebody point me into the right direction?
/David
Solved! Go to Solution.
06-27-2019 01:36 PM
I believe this is a reference to a guide that no longer exists. However, here is configuration guidance for HA using HSRP with CUBE.
Brandon
06-27-2019 01:36 PM
Brandon
06-28-2019 06:43 AM
It is in the same configuration guide. You need to refer Chapter 69 page 837.
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/cube/configuration/cube-book.pdf
