CUBE NBR Dialpeer forking using Loopback Interfaces
rchaseling
Level 4
Level 4
Hi all,
Jsut want to check something. I see in the guide here - https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/cube/configuration/cube-book/voi-ntwk-based.html
That it says Network-based recording is not supported for the following calls:
  • Real-time Transport Protocol (RTP) loopback calls
Does this mean that if my CUBEs use Loopback addresses (ie my dialpeers are all bound to Loopbacks) that I cannot use this type of recording?
Cheers
