Explorer
CUBE: What is the difference betwen CUBE-T-STD and CUBE-L-STD
For the CUBE, What is the difference betwen CUBE-T-STD and CUBE-L-STD.
If it is a trunk session? How many calls the trunk can hold? We can seee this on the Licensing
L-CUBE : Top-level part number. Select this first
 - CUBE-T-STD: One Standard Trunk Session License
 - CUBE-L-STD: One Standard Lineside License
Another Question: Does this license can be installed on a CSR1000v?
1 REPLY 1
Hall of Fame Cisco Employee
Re: CUBE: What is the difference betwen CUBE-T-STD and CUBE-L-STD
Watch
https://community.cisco.com/t5/collaboration-documents/voice-of-the-engineer-voe-events/ta-p/3621363
Updates to SIP Trunking for On-Prem Deployments
java
if this helps, please rate
Content for Community-Ad
August's Community Spotlight Awards
