01-14-2021 08:57 AM
We have had an intermittent issue where users cannot access their voicemail and incoming calls forwarded to voicemail just ring without answer. After looking into the failed calls it became apparent the issue is with the subscriber. All the VM Ports are registered ok but the subscriber is not answering the calls.
For now I have stopped the Sub taking calls and users are not seeing any issues.
When I look at service management the Sub is showing a number of services such as Connection Message Transfer Agent as deactivated although if I look from the cli with utils service list that service shows as started. Is that expected behaviour when running in HA? Any ideas what might be causing the Sub to stop responding to calls?
Any thoughts would be appreciated.
Thanks.
01-14-2021 09:59 AM - edited 01-14-2021 10:00 AM
CUC integrations is it SIP or SCCP.
if SCCP do you have ports configured for both primary and secondary CUC.
01-14-2021 11:16 AM
It is a SCCP integration. Yes, their are ports configured for both CUC servers and the Sub ports were registered ok.
01-21-2021 01:10 AM - edited 01-21-2021 01:12 AM
Hi Gary,
Can you check if you have the same language packs / locales on the Unity Connection Subscriber and that they match up with what's on the Unity Publisher? I have seen an issue like this occur before when the locales were missing from the Subscriber.
01-22-2021 12:44 PM
In the end we rebooted the Sub as we could see no obvious issues and it has been working fine ever since....one of those ones
