04-03-2019 11:14 AM
Dear All,
Hope this finds you well,
Kindly we have a problem the phones not registering in the CUCM it said TFTP Timeout
I think the problem in the TFTP because it is not running and when I want to start the service it is start from less then 30 seconds and again stopped
the old phones working normally but we can't add any new phones because the TFTP
thanks in advance for your help
Solved! Go to Solution.
04-04-2019 01:16 PM
04-04-2019 05:46 AM
You will need to review TFTP logs to see what causes the service to fail to start. Have you attempted to reboot the server?
04-04-2019 08:01 AM
thanks for the reply
no I didn't restart the server,
I check the log file and I found this message
00063440.000 |13:22:28.638 |FileHead |UTC:+03:00,Date: 2019/03/31, AppName: TFTP, AppId: 600, AppNodeId: 1, AppVersion: 12.0.1.10000-10, HostName: DAR-CUCM, HostIPAddress: 10.10.10.252, AppStartTime: 2019/03/19 18:04:22, FileNumber: 19, TraceVer: 3.0
00063441.000 |13:22:28.638 |AppInfo |SDIControlLayerFailed - Failed to update trace logging or alarm subsystem for new settings. Error:2 Reason:SDI control re-read failed on CN_SERVICEABILITY notification App ID:Cisco Tftp Cluster ID:StandAloneCluster Node ID:DAR-CUCM
00063442.000 |13:22:28.650 |AppInfo |SDIControlLayerFailed - Failed to update trace logging or alarm subsystem for new settings. Error:2 Reason:SDI control re-read failed on CN_SERVICEABILITY notification App ID:Cisco Tftp Cluster ID:StandAloneCluster Node ID:DAR-CUCM
00063443.000 |13:22:28.652 |AppInfo |SDIControlLayerFailed - Failed to update trace logging or alarm subsystem for new settings. Error:2 Reason:SDI control re-read failed on CN_SERVICEABILITY notification App ID:Cisco Tftp Cluster ID:StandAloneCluster Node ID:DAR-CUCM
00063444.000 |13:22:28.653 |AppInfo |SDIControlLayerFailed - Failed to update trace logging or alarm subsystem for new settings. Error:2 Reason:SDI control re-read failed on CN_SERVICEABILITY notification App ID:Cisco Tftp Cluster ID:StandAloneCluster Node ID:DAR-CUCM
00063445.000 |13:22:28.653 |AppInfo |SDIControlLayerFailed - Failed to update trace logging or alarm subsystem for new settings. Error:2 Reason:SDI control re-read failed on CN_SERVICEABILITY notification App ID:Cisco Tftp Cluster
04-04-2019 09:00 AM
What is the status of your cluster, i.e. when you login via RTMT are you seeing any errors? Is DB replication working correctly?
04-04-2019 10:21 AM
04-04-2019 11:11 AM
Is the phone properly defined in CUCM?
Have you done factory reset on the phone?
Is the proper TFTP IP address show up on the phone?
What do you see on the phone's console log (browse the IP address of the phone)
04-04-2019 11:24 AM
04-04-2019 12:05 PM
Looks like the phone is unable to reach your TFTP, see:
2367 NOT Apr 04 19:38:13.314481 (2894:2894) dgetfile-HTTP connection/TFTP timeout, try next node.
2368 NOT Apr 04 19:38:13.314573 (2894:2894) dgetfile-HTTP/TFTP error timeout...
2369 NOT Apr 04 19:38:13.314909 (2894:2894) dgetfile-HTTP/TFTP sleep 1 secs...
Is there a firewall/ACL between the phone and CUCM TFTP?
Are you able to ping the phone's IP address from CUCM server?
04-04-2019 12:16 PM
04-04-2019 01:16 PM
07-15-2019 03:05 AM
The same thing is happening with me, how can I do the update to solve this problem? Can you give me the steps? I need your help to solve this without loose the the environment already configured.
07-16-2019 01:38 AM
Did you try the methods above ? if it didn't work the upgrade is easy .
1- First take a backup in case something happen
2- Download the right version for the software upgrade
3- Go to the browser and go to Cisco Unified OS Administration.
4- Go the tape Software Upgrade / Install & Update
5- then fill the path for your downloaded software.
you will need a SFTP server to set the path so the server can download the software from your PC
thanks
07-23-2019 12:52 AM
Hi Saifeldin
I'm in problem trying to set a local SFTP server, i need your help with the program you already used and the steps. Thanks in advance
Hugs
08-04-2019 01:37 AM
08-07-2019 06:59 AM
