CUCM 8.6 Incoming Call issue
bob.bartlett
I have a new 8.6 install and I can call out and can call between phones on the CallManager but incoming calls get dropped without even ringing to the phone.  any thoughts...
Jaime Valencia
Debug the GW to find the reason code for this, then you can get an idea of what to fix.
java
if this helps, please rate
this is an intercluster trunk between 2 Call Managers.
Check IPs, incoming CSS, codecs, if no avail, review CUCM traces.
java
& make sure IPs of all nodes (PUB and SUBs call manager)'s are mentioned in the ICT under "Remote Cisco Unified Communications Manager Information" at both CUCM side.
Suresh
