02-22-2019 07:40 AM
Hi All - I'm new to the SQL portion of UCM and was wondering if anyone had some sql strings for the following scenarios?
Thank You in advance to the amazing Cisco Support community!
Solved! Go to Solution.
02-22-2019 09:03 PM
Hi there
https://developer.cisco.com/docs/axl-schema-reference/
Hope this helps
Cheers
Rath!
***Please rate helpful posts***
02-22-2019 08:22 AM
That's the least recommended way to do any MACD in CUCM, and not something we encourage or support (few exceptions when there is absolutely no other way to do it, and most likely TAC will provide the exact instructions)
You should use either BAT, the CUCM GUI, or if you want to script this, then use AXL.
02-22-2019 09:16 AM
Thanks Jaime!
Would you have any beginner advice / website or guides that would help me with AXL? Perhaps some steps?
02-22-2019 11:42 AM
All the AXL documentation, schema, etc can be found at DevNet, and you want to use a program like SoapUI for this to begin with.
02-22-2019 12:31 PM
Thank You
02-22-2019 09:03 PM
Hi there
Hope this helps
Cheers
Rath!
02-26-2019 01:04 PM
Thanks Ratheesh! That is extremely helpful
