CUCM SiP Trunk to CUBE Call disconnection problem issue
m.soleimani
I have cisco call manger 12.5 and cisco ISR 4451 with CUBE-Version : 11.5.2, I have sip trunk to my CUBE, when my client makes an Outbound call to CUBE every things  is fine but when other call party disconnect the call, my client side call does not disconnect, but if my client side disconnects the call, other call party will disconnect.
my configuration:
voice service voip
no ip address trusted authenticate
mode border-element license capacity 999999
allow-connections sip to sip
sip
header-passing
error-passthru
no update-callerid
early-offer forced
midcall-signaling passthru
dial-peer voice 200 voip
description CUCM to CUBE
session protocol sipv2
incoming called-number .T
voice-class codec 2
no voice-class sip early-offer forced
voice-class sip bind control source-interface Loopback1
voice-class sip bind media source-interface Loopback1
dtmf-relay rtp-nte
no vad
dial-peer voice 500 voip
description MCI Calls CUBE to SP
destination-pattern +(XX)9[19][0-9].......
session target ipv4:10.17.9.146
session transport udp
voice-class codec 1
voice-class sip early-offer forced re-negotiate always
voice-class sip bind media source-interface Loopback2
dtmf-relay rtp-nte sip-notify
my log :
When other party disconnect :
Jul 13 14:38:28.840: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:02181712001@10.14.13.250:5060 SIP/2.0
Via: SIP/2.0/UDP 10.17.9.146:5088;branch=z9hG4bKkjtenusaqpajknjkha0sajjup;X-DispMsg=1419
Call-ID: 4DC58D40-C44D11EA-86578465-404DF94F@10.14.13.250
From: <sip:+XX2181716663@10.17.9.146>;tag=hacbbepe-CC-1000-OFC-110
To: "Mohammad Soleimani"<sip:02181712001@10.14.13.250>;tag=A0BC805-149A
CSeq: 1 BYE
Max-Forwards: 70
Reason: Q.850;cause=16;text="Normal call clearing"
Content-Length: 0
Jul 13 14:38:28.841: //881/76B20D800000/SIP/Msg/ccsipDisplayMsg:
Sent:
E807-R4451-01#SIP/2.0 200 OK
To: "Mohammad Soleimani" <sip:02181712001@10.14.13.250>;tag=A0BC805-149A
Date: Mon, 13 Jul 2020 14:38:28 GMT
Server: Cisco-SIPGateway/IOS-16.3.5
CSeq: 1 BYE
Session-ID: e7721fdc8b7941aac33eb625609f0ba0;remote=57628614c9ca5d74a8df2acec3a5ddb4
Content-Length: 0
call does not disconnect automatically and my client Disconnect call manually:
Jul 13 2020 19:08:33.841 Asia/Te: %SIP-3-INTERNAL: Cannot insert call history entry for callID : 880
E807-R4451-01#
E807-R4451-01#
Jul 13 14:39:19.480: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:+XX2181716663@10.14.13.250:5060;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 172.17.54.33:5060;branch=z9hG4bKcc1d6869906b
From: "Mohammad Soleimani" <sip:02181712001@172.17.54.33>;tag=54995~e23d8f3b-fa5e-49ff-88db-477d8f91a7f1-25036603
To: <sip:+XX2181716663@10.14.13.250>;tag=A0BC947-2393
Date: Mon, 13 Jul 2020 14:38:08 GMT
Call-ID: 76b20d80-1eb1e319-c575-213611ac@172.17.54.33
User-Agent: Cisco-CUCM12.5
Max-Forwards: 70
P-Asserted-Identity: "Mohammad Soleimani" <sip:02181712001@172.17.54.33>
CSeq
E807-R4451-01#: 105 BYE
Content-Length: 0
Sent:
SIP/2.0 481 Call Leg/Transaction Does Not Exist
CSeq: 105 BYE
Content-Length: 0
5 Replies 5
m.soleimani
debug ccsip calls
E807-R4451-01#
Jul 13 14:47:32.613: //883/BDECCE000000/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x0x7F5FE0833B48
State of The Call : STATE_DEAD
TCP Sockets Used : NO
Calling Number : 02181712001
Called Number : +XX2181716663
Source IP Address (Sig ): 10.14.13.250
Destn SIP Req Addr:Port : 10.17.9.146:5060
Destn SIP Resp Addr:Port : 10.17.9.146:5085
Destination Name : 10.17.9.146
E807-R4451-01#
Jul 13 14:47:32.613: //883/BDECCE000000/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream : 1
Negotiated Codec : g711alaw
Negotiated Codec Bytes : 160
Nego. Codec payload : 8 (tx), 8 (rx)
Negotiated Dtmf-relay : 6
Dtmf-relay Payload : 101 (tx), 101 (rx)
Source IP Address (Media): 10.14.176.250
Source IP Port (Media): 9448
Destn IP Address (Media): 10.17.19.30
Destn IP Port (Media): 12080
Orig Destn IP Address:Port (Media): [ - ]:0
Disconnect Cause (CC) : 16
Disconnect Cause (SIP) : 200
E807-R4451-01#
Jul 13 2020 19:17:37.612 Asia/Te: %SIP-3-INTERNAL: Cannot insert call history entry for callID : 882
Jul 13 14:47:37.612: //882/BDECCE000000/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x0x7F5FE08004C8
TCP Sockets Used : YES
Destn SIP Req Addr:Port : 172.17.54.33:5060
Destn SIP Resp Addr:Port : 172.17.54.33:32910
Destination Name : 172.17.54.33
E807-R4451-01#
Jul 13 14:47:37.612: //882/BDECCE000000/SIP/Call/sipSPIMediaCallInfo:
Media Stream : 1
Source IP Address (Media): 10.14.13.250
Source IP Port (Media): 9446
Destn IP Address (Media): 10.99.98.32
Destn IP Port (Media): 24614
Disconnect Cause (SIP) : 500
Please Guide me for this issue...
https://community.cisco.com/t5/ip-telephony-and-phones/cube-does-not-forward-bye-from-sip-sp-on-outbound-calls/td-p/3373594
 I Found this and I changed my dial-peers  CUCM to UDP but the problem still exists. any suggestion???
Did you try to make in cube a profile (it depands to your ver) wit this
request INVITE sip-header Session-ID remove
Apply this profile to your outgoing trunks
Thanks for your feed back.
the problem was about Network Access between CUBE and CUCM (SIP 5060) and after granted this access problem was solved!!!
