Walkthrough Wednesdays
2694
Carl Fitzsimmons
Beginner
CUCM v10 Pre-Pend to 'Missed calls' when using 'Call' soft key
I have CUCM v10.5.2.15900-8 all aspects are working fine. We are fully integrated with Unity Connection, IVR,and internal CM 4 digit DN works 100% except for dialing behavior when a user selects 'Missed calls', scrolls to a 'Missed call' and selects 'Call'
Calls that are missed are successfully placed on that phones 'Missed calls'  list as xxxxxxxxxx
Internally when we call out users need to start with 91 for national calls then they dial the desired number xxxxxxxxxx. The 9 is stripped and the call proceeds as 1xxxxxxxxxx
If I 'Edit dial' I can PrePend 91 and the call goes out successfully
How do I automatically PrePend 91 to 'Missed calls' when the user selects 'Call' soft key so they successfully go out verses receiving 'Your call cannot be completed as dialed. Please consult your directory and call......' ?
1 ACCEPTED SOLUTION
Slavik Bialik
Rising star
If the calls from the PSTN is passing through a Voice Gateway / CUBE first, I would add the 9 over there. Although you can do it on CUCM also, but personally I'm more used to do it on the voice gateway.
Just add this to your CLI:
voice translation-rule 1
 rule 1 // /9/
voice translation-profile add-prefix-9-to-CID
 translate calling 1
dial-peer voice 2000 voip
 description Outbound VoIP Dial-Peer to CUCMs
 translation-profile outgoing add-prefix-9-to-CID
 session protocol sipv2
 session transport tcp
 voice-class codec 1
 dtmf-relay rtp-nte
 no vad
Associate this translation profile on the outbound dial-peer towards your CUCM.
If not, you have settings on the SIP Trunk in CUCM under the "Incoming Calling Party Settings", you can prefix the calling party number with 9 over there. I never used it, but I think it also should do the trick.
5 REPLIES 5
Jaime Valencia
Hall of Fame Cisco Employee
This is a topic that has been discussed a lot of times before at CSC, have you looked at any of those previous threads on the same topic?
java
if this helps, please rate
I have followed several links on this activity and none have helped
https://supportforums.cisco.com/t5/ip-telephony/adding-prefix-to-missed-calls/td-p/2525690
https://supportforums.cisco.com/t5/ip-telephony/how-do-i-automatically-add-prefix-9-to-missed-calls/td-p/2782840
https://supportforums.cisco.com/discussion/12679101/cucm-100-how-translate-or-transform-add-prefix-incoming-call-pstn
Whenever I add 91 - 9 to get outside 1 for National anywhere in Call Manager Calling Party or Called Party  Transform Mask or Prefix digits in either
Route Group or
Service Parameter Configuration - Call Manager - Advanced - Incoming Calling Party National
We receive the error message described above or
The number received on the called phone is not correct and when this occurs still only works by adding the 91 prefix
When changes have been removed so we are back to the beginning all calls placed to outside go through and are presented correctly however whenever a phone calls into us and is left on 'Missed calls' list that phones national number xxxxxxxxxx is kept and requires the user to select 'Edit dial' to manually prepend 91. When they do the call goes out
Slavik Bialik
Rising star
 rule 1 // /9/
 translate calling 1
 voice-class codec 1
 dtmf-relay rtp-nte
 no vad
@Slavik Bialik
First - thanks to everyone who responded.
Second - I modified this
rule 1 // /9/
To this
voice translation-rule 2
rule 1 // /91/
as I already had a voice translation rule. I then followed your other suggestions and it worked perfectly. Thanks
At this time I am not certain how this will work when non US calls are placed. My guess is the dial string will be manipulated by adding 91. Not certain how to address that but at this time Thank You
Now I will move on to finding out why Vitelity SIP does not always provide ring tone on out bound calls.
Content for Community-Ad
Spotlight Awards 2021
