07-30-2012 05:51 AM - edited 03-19-2019 05:18 AM
Hi All!
I need to obtain the installation package of CUEAC for evaluation purposes.
But on the site http://cisco.com/go/ac I can download only Arc Enterprise & Arc Express products.
As far as I understand products made for Cisco are different from native Arc software.
Where is it possible to download CUEAC?
07-30-2012 06:59 AM
Hi Aruzin,
The downloads available are the correct Department, Businees or Enterprise
Console versions. Don't let the names distract you
http://cisco-ac.arcsolutions.com/UserWebSite/cisco/Engineers/ciscoDownloads.aspx
Cheers!
Rob
"Always movin' ahead and never lookin' back" - Springsteen
07-30-2012 07:10 AM
Hi Rob!
My colleague has registered on this site and indeed he can download Department, Businees and Enterprise Consoles.
I can see only Arc Enterprise and Arc Express using exactly the same link.
Probably I have different permissions or performed slightly different initial registration.
Alexander
07-30-2012 07:13 AM
Hi Alexander,
Have you tried to re-register? I just registered this AM and have access
to the proper versions
Cheers!
Rob
07-30-2012 08:25 AM
The re-registration helped.
Thanks!
