12-22-2011 06:11 AM - edited 03-19-2019 04:09 AM
Hi all,
I have noticed that when configuring CUPC under CUP 8.5 you have to define an active and a maximum two backup TFTP servers in the settings page for CUPC (Application>Cisco Unified Personal Communicatore>Settings). In other word you have to define the CCM group that will be used by all CUPC clients. Does it mean that all the CSF device that I have to configure under CUCM must have a device pool with this very same CCM group?
Best Regards,
Solved! Go to Solution.
12-22-2011 06:33 AM
No, you're confusing things.
The TFTP is where the phones get their config file, that's it.
The config file they get from the TFTP is what contains the CUCM group config, it can be the same server(s) or other servers from your cluster depending on your config/deployment.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
12-22-2011 06:33 AM
java
