08-30-2010 09:44 PM - edited 03-19-2019 01:29 AM
I'm trying to get federation working with googletalk and I'm stuck. I have CUPS 8 with CUPC 8 clients.
I have defined the following SRV records:
While we're federating with a number of other services, some services aren't currently accessible through the Google Talk network, and your users won't be able to chat with users of those services.
If you'd like your users to have the ability to chat with people connected to the Google Talk network through federated networks, you'll need to edit your Service (SRV) records. You don't need to edit your SRV records for your users to chat with other Google Apps and Gmail users. SRV records are managed by your domain host. We suggest contacting your domain host to find out if you have access to SRV records and how you can make modifications.
When you enter the following information, make sure to replace gmail.com with your domain. Don't replace google.com.
_xmpp-server._tcp.gmail.com. IN SRV 5 0 5269 xmpp-server.l.google.com.
_xmpp-server._tcp.gmail.com. IN SRV 20 0 5269 xmpp-server1.l.google.com.
_xmpp-server._tcp.gmail.com. IN SRV 20 0 5269 xmpp-server2.l.google.com.
_xmpp-server._tcp.gmail.com. IN SRV 20 0 5269 xmpp-server3.l.google.com.
_xmpp-server._tcp.gmail.com. IN SRV 20 0 5269 xmpp-server4.l.google.com.
_jabber._tcp.gmail.com. IN SRV 5 0 5269 xmpp-server.l.google.com.
_jabber._tcp.gmail.com. IN SRV 20 0 5269 xmpp-server1.l.google.com.
_jabber._tcp.gmail.com. IN SRV 20 0 5269 xmpp-server2.l.google.com.
_jabber._tcp.gmail.com. IN SRV 20 0 5269 xmpp-server3.l.google.com.
_jabber._tcp.gmail.com. IN SRV 20 0 5269 xmpp-server4.l.google.com.
I'm basically lost and could really use some direction on how to enable federation with googletalk from CUPS 8. I'm very new to XMPP...
I have CUPS 8 configured to "require TLS" as I saw it mentioned that Googletalk requires TLS.
From CUPC 8 client, I go to "add a contact" and enter myusername@gmail.com and of course nothing happens. Not seeing much traffic coming into the FW on that port so that makes me think something is missing...
Any assistance would be greatly appreciated.
Ted
06-19-2011 03:59 AM
I am also working on the same, were you able to do this? the guide says this:
Cisco Unified Presence supports XMPP federation with GoogleTalk over TCP. XMPP federation with GoogleTalk over TLS is not supported.
Mani
06-26-2012 07:22 AM
I try to establish a XMPP federation with google talk but didn’t work (without TLS).
Did you found the problem solution?
