Cisco Community Designated VIP Class of 2020
5959
Beginner
CUPS and 3rd party XMPP clients
CUPS allows third party XMPP clients. We tested it with Pidgin on Windows, IM+ on iOS.
Now, how can we ensure that password are not send "in the clear", but protected by TLS or at least by hashing ?
Regards.
J.Ph Papillon
Everyone's tags (3)
4 REPLIES 4
Beginner
Re: CUPS and 3rd party XMPP clients
Wireshark?
Beginner
3rd party xmpp clients will use SASL plain to authenicate with CUP. The password will be sent base64 encoded to CUP. However, to fully secure the client, it should also use TLS when also using SASL plain.
Steve
Beginner
We have CUCM 10.0 and CUPS 10.0 installed inhouse and I am writing a XMPP client using Matrix XMPP API to connect to CUPS. It always failed on sasl authehtication:
SEND: <stream:stream xmlns:stream="http://etherx.jabber.org/streams" xmlns="jabber:client" to="cucm10.local" version="1.0" >
RECV: <stream:stream xmlns:stream="http://etherx.jabber.org/streams" xmlns="jabber:client" xml:lang="en-US.UTF-8" id="295BA5170E" from="cucm10.local" version="1.0" >
RECV: <stream:features xmlns:stream="http://etherx.jabber.org/streams">
  <starttls xmlns="urn:ietf:params:xml:ns:xmpp-tls">
    <required />
  </starttls>
</stream:features>
SEND: <starttls xmlns="urn:ietf:params:xml:ns:xmpp-tls" />
RECV: <proceed xmlns="urn:ietf:params:xml:ns:xmpp-tls" />
  <mechanisms xmlns="urn:ietf:params:xml:ns:xmpp-sasl">
    <mechanism>PLAIN</mechanism>
    <mechanism>CISCO-VTG-TOKEN</mechanism>
  </mechanisms>
</stream:features>
SEND: <auth mechanism="CISCO-VTG-TOKEN" xmlns="urn:ietf:params:xml:ns:xmpp-sasl">dXNlcmlkPWpvc2llbEBjdWNtMTAubG9jYWwAdG9rZW49YWJjZA==</auth>
RECV: <failure xmlns="urn:ietf:params:xml:ns:xmpp-sasl">
  <temporary-auth-failure />
</failure>
RECV: </stream:stream>
SEND: </stream:stream>
this is configured on CUCM 10.0
The end user userid: JosieL
Password: abcd
pin: 1234
XMPP domain: cucm10.local
I tried to use both "abcd" and "1234" to construct the sasl string in this format. None of them works for me:
JosieL@cucm10.local\01234 or JosieL@cucm10.local\0abcd in base64 format
Can anyone tell me what the problem is? I have been struggling with this issue for a couple of days.
Any help is appreciated
Rising star
This community does not provide technical support and is not staffed with technical support experts. I recommend you post this and future technical support questions to the Cisco Support Community (https://supportforums.cisco.com/index.jspa) where our Cisco technical support experts provide assistance. Another option is to open a ticket with the Cisco Technical Assistance Center (www.cisco.com/go/support) to get expert debugging assistance.
We hope to hear from you again.
Kelli Glass
Moderator for the Cisco Collaboration Community
Content for Community-Ad
FusionCharts will render here
