ā03-02-2012 08:39 AM - edited ā03-19-2019 04:31 AM
We are doing the rebuild of the CUPS 8.5(2) , which is currently active. But previously we upgraded form CUPS 8.0 to 8.5(2) and the license is for 8.0 only.
After rebuilding the CUPS directly to CUPS8.5(2) , shall we upload the license file on the CUPS the & restore the Backup ?
does it work please suggest....
Thanks in advance..
ā03-02-2012 09:16 AM
admin:show version active
Active Master Version: 8.5.2.10000-49
Active Version Installed Software Options:
No Installed Software Options Found.
admin:show version inactive
Inactive Master Version: 8.0.1.10000-54
Inactive Version Installed Software Options:
Going to rebuild the server with CUPS 8.5.2.10000-49. We are having the
UCSInstall_CUP_8.5.2.10000-49.sgn.iso_part1of2 & UCSInstall_CUP_8.5.2.10000-49.sgn.iso_part2of2 file , will the rebuild work using this file pl suggest.
ā01-29-2013 02:07 AM
Hi All,
Just want to close this thread as rsolved :
Resolution: We have contacted CIsco TAC and downloaded the Bootable Version & successfully rebuild the server. And the Lic are also usefully after upgrade..
Rgds,
Aditya
