04-30-2015 07:45 AM - edited 03-19-2019 09:32 AM
I've been looking around to find the preferred design when deploying a UC environment with UCM, Expressway C&E and a VCS control for registration and call control of legacy VC endpoints.
Between UCM & Expressway-C: SIP trunk
For the VCS Control I prefer neighbouring with Expressway because it is easier with the zones and search rules to make a routing plan.
But for each cal going across the Expressway-C (UCM-> Exp-C -> VCS Control) a RMS license will be consumed.
So is it better to make a SIP trunk between VCS Control and UCM to avoid the use of RMS's? But how to route calls on the UCM when you can only the poor 'SIP Route Pattern' routing function of the UCM?
Any advice / thoughts on this?
rgds, Geert.
05-01-2015 06:19 AM
Why do you have Exp-C and VCS-C both in the path? They are the same thing, so what is the intent here?
05-03-2015 10:31 PM
You cannot register devices on a Exp-C. For this you need to use a VCS-C to register legacy vc endpoints such as MXP, Polycom, etc.
05-04-2015 08:11 AM
Chris is referring to this:
05-05-2015 08:23 AM
This are the possible paths:
VC endpoint registered on UCM > UCM > EXP-C > VCS-C > Legacy endpoint registered on VCS-C
or
VC endpoint registered on UCM > UCM > VCS-C > Legacy endpoint registered on VCS-C
The disadvantage of the last one is that on UCM you have less routing possibilities than with using the Exp-C search rules.
Note there's also a EXP-E in the deployment for B2B calls on the Internet.
VC endpoint registered on UCM > UCM > EXP-C > EXP-E > Internet > B2B endpoints
