Walkthrough Wednesdays
1134
john-guy
Beginner
Device Pool - How many devices are supported for each Device Pool?
Hi CUCM Community,
I need assistance locating the number of endpoints or devices supported for a Device Pool.
If you know Cisco's recommended number for a Device Pool can you note the section where its indicated in the SRND.
Your help is appreciated
John
4 REPLIES 4
Jaime Valencia
Hall of Fame Cisco Employee
There's no limit, other than the amount of devices supported by your system.
java
if this helps, please rate
Hi Jamie,
Does Cisco have a Best Practice when it comes to assigning a specfic amount of "members" to a Device Pool?  Many people seem to have their own rule when it comes to assigning or not to exceed a specific number of members within a Device Pool.
I appreciate your input
Thank you
John
Jaime Valencia
No, there's no best practice, that's completely up to you and what you need.
java
David Hailey
Advisor
I've never seen anyone limit the number of devices in a device pool; however, it is common to use device pools to group devices based on common characteristics such as physical location, etc.
Hailey
Content for Community-Ad
Spotlight Awards 2021
