960
Highlighted
Enthusiast
Difference in UCL and CUWL
Hi all,
I am trying to understand the difference between UCL and CUWL licensing, the more i read the more i get confused. Is there a guide or presentation that helps dummies like us to understand what is the difference and when to use which ??
6 REPLIES 6
Highlighted
Enthusiast
Anyone pls ?
Highlighted
Hall of Fame Master
Highlighted
Enthusiast
Sir, it doesnt tell when to use which ?
Highlighted
Hall of Fame Master
Sure it does, if you need all the user features CUWL provides you buy CUWL for that user, some features are pretty much the same for CUWL and Enhanced UCL, so the main difference is how many devices the user will have. With UCL Enhanced for example a user can have up to 2 devices where with CUWL the user can have up to 10.
HTH,
Chris
Highlighted
Beginner
Re: Difference in UCL and CUWL
So, we have purchased multiple desktop VTC units, If I need to go to a Enterprise solution to place all of desktop's under the same unified communications umbrella, will I be able to move the desktop endpoints and protect my current investment in the desktop units?
Highlighted
Contributor
If by VTC you mean video conferencing, you can licence these with UCL licensing. Exact recommendation will depend on your scale, existing licences, and version.
Content for Community-Ad
Future of Work Virtual Summit Day 5
Cisco COVID-19 Survey
