07-25-2011 09:55 AM - edited 03-19-2019 03:20 AM
I found we may allow users to tranfer their calls in CM or UC, is it different?
Solved! Go to Solution.
10-22-2014 02:09 PM
UC will use it it's own Restriction Tables to block outgoing calls/transfers. This feature is utilized for Toll Fraud prevention.
In the end all call processing routes through CM. Initially it will go through UC then to the CM and GW.
HTH,
Justin
07-25-2011 10:42 AM
Generally, voicemail systems are restricted from making external transfers for security reasons.
While you may allow a user to set a call forward all either place, doing it through CallManager is generally less restrictive.
Cliff
Please rate helpful posts
07-25-2011 01:07 PM
Thx, i got it.
10-22-2014 02:09 PM
HTH,
Justin
