DRS Issue with Unity Connection
Hello all,
We're having issues with the DRS backup of a Cisco Unity Server, version 12.0.1.21900-10.
It is a standalone server.
When the CUC feature is selected, I receive the following error:
Failed to initiate backup. Server [CUC01], component [CLM] requires component [PLATFORM] to be registered.
If I don't select the CUC feature, the backup runs normally.
I restarted DRF Master and Local Agents, but it still didn't work.
Then I went to CLI and ran the command utils disaster_recovery show_registration and can't find PLATFORM registered, CLM is registered normally.
What could be the reason to the PLATFORM component missing?
Could you please share any ideas on how to fix this?
Regards and than you in advance.
Open a TAC case for this, most likely this will require root access
java
if this helps, please rate
Sadav Ansari
Go to CUC OS Asmin page and recreate IPSec certificate then restart DRF Master  and Local, Hope it will resolve your issue.
Pls rate if its “Helpful”. If this answered your question pls click “Accept as Solution”.
Hello, Sadav.
I regenerated the IPSec certificate and restarted Master first and then Local. The certificate had an expiry date of 2025, now it has 2026. Unfortunately the issue is still happening.
I don't know why the PLATFORM component is not showing up.
java
Kindly raise a TAC case for this also share the solution once issue resolved for better visibility to our community members.
