05-06-2021 03:23 AM
Hi Team,
I am new here and this is my first post in the community,
I am having an issue with Cisco Gateway with DTMF and RTP. I have configured the dial-peers as per the service provider requirement.
but the DTMF and RTP are not working. any assistance on how to start troubleshooting about checking if the RTP and DTMF are reaching Cisco Gateway from the Service provider.
Mohammed
05-06-2021 08:11 AM
That would depend on your configuration. You haven't mentioned if this is a SIP carier and you are doing SIP trunks or if it is a PRI or what. If it is SIP then you need to make sure that you have dtmf-relay rtp nte on the dial-peer. What you are looking for from the carrier is in the SIP invite in the SDP section. You are looking for a line similar to this one
m=audio 19838 RTP/AVP 0 101
The 0 indicates g.711ulaw and the 101 indicates DTMF RFC2833 or rtp nte
05-06-2021 10:30 AM
Can you share configuration you made and the ISP requirement.
05-06-2021 12:58 PM
Dears Thanks a lot for the response, kindly find the below configuration details.
IN dial-peer voice 203 VoIP i have configured a manual RTP type to 116 because SP was saying that the payload was sending different. so still it is the same issue but for dial-peer voice 101 VoIP is the same as mentioned.
ART_CC_SIP_GW#sh run
Building configuration...
Current configuration : 3432 bytes
! Last configuration change at 02:24:38 UTC Wed May 5 2021 by root
version 16.9
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname ART_CC_SIP_GW
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable secret 5 $1$bake$pVlvvzAko6aDq2B/zM1sV0
no aaa new-model
login on-success log
subscriber templating
voice service voip
ip address trusted list
ipv4 10.80.92.13
ipv4 10.80.92.16
mode border-element license capacity 10
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
voice register pool-type SIP
voice-card 0/4
no watchdog
license udi pid ISR4331/K9 sn FDO19230EJ7
license accept end user agreement
no license smart enable
diagnostic bootup level minimal
username root password 0 XXXXX
redundancy
mode none
interface GigabitEthernet0/0/0
ip address 10.189.131.150 255.255.255.252
negotiation auto
interface GigabitEthernet0/0/1
ip address 10.80.92.111 255.255.255.0
negotiation auto
interface GigabitEthernet0/0/2
no ip address
negotiation auto
interface Service-Engine0/4/0
vrf forwarding Mgmt-intf
no ip address
negotiation auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0
ip default-network 10.189.131.0
ip route 0.0.0.0 0.0.0.0 10.170.17.193
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/0
ip route 10.141.40.233 255.255.255.255 10.189.131.149
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
telephony-service
max-conferences 8 gain -6
transfer-system full-consult
dial-peer voice 203 voip
description ####Transfering Calls From VGW to the Main CIC IPPBX####
destination-pattern 8386350
rtp payload-type cisco-codec-ilbc 99
rtp payload-type nte 116
session protocol sipv2
session target ipv4:10.80.92.13:5060
session transport udp
voice-class sip options-keepalive up-interval 12 down-interval 65 retry 3
codec g711alaw
no vad
dial-peer voice 201 voip
preference 1
destination-pattern 8386300
dtmf-relay rtp-nte
codec g711alaw
no vad
dial-peer voice 101 voip
description ####Outgoing calls Through STC SIP Trunk####
destination-pattern .
session target ipv4:10.141.40.233:5060
dtmf-relay rtp-nte
codec g711alaw
no vad
line con 0
transport input none
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password XXXXXX
login local
transport input ssh
line vty 5
password XXXXXX
login local
transport input ssh
line vty 6 15
login local
transport input ssh
Let me if you i need to provide more details.
Mohammed
05-06-2021 01:39 PM
This is good information.
I'm wondering about these in the 203 dial-peer
Can you send the output from debug ccsip messages so we can see the invite and how the carrier is responding?
05-09-2021 12:44 AM
05-06-2021 07:45 PM - edited 05-06-2021 07:49 PM
Hope you are in the Saudi, can you try the below mentioned DTMF.
https://community.cisco.com/t5/telepresence-and-video/saudi-telecom-sip-configuration/td-p/2829354
05-09-2021 12:30 AM
Hi, Nithin,
I have tried this as well, still no success
05-09-2021 04:19 AM - edited 05-09-2021 04:19 AM
Try the below. shutdown dial-peer 203.
Shutdown
preference 1
dtmf-relay rtp-nte
codec g711alaw
no vad
dtmf-relay rtp-nte
codec g711alaw
no vad
05-10-2021 05:16 AM
Hi Nithin,
Thanks for the update,
Actually, I have tried this command and getting the below error
ART_CC_SIP_GW(config-dial-peer)#rtp payload-type nte 116
ERROR: value 116 in use!
05-10-2021 05:50 AM
On which dial-peer you tried this ?
05-10-2021 05:58 AM
I tried on both ones,
Firstly I have deleted the 203 dial-peer and shutdown the 201 dial-peer
first I tried this command on 101 then the 201 dial-peer
I can see that this command is not working in any dial-peer. I think this payload is using by another service as below. I used
GW#sh dial-peer voice 201
RTP dynamic payload type values: NTE = 101
Cisco: NSE=100, fax=96, fax-ack=97, dtmf=121, fax-relay=122
CAS=123, TTY=119, ClearChan=125, PCM switch over u-law=0,
A-law=8, GSMAMR-NB=117 iLBC=116, AAC-ld=114, iSAC=124
MP4A-LATM=111, lmr_tone=0, nte_tone=0
h263+=118, h264=119
G726r16 using static payload
G726r24 using static payload
RTP comfort noise payload type = 19
05-09-2021 12:51 AM
One strange thing I found, I am not sure if it is correct or not but for me, it looks strange. the thing is if I am removing the Outbound dial-peer the incoming calls are not working. it gives as network busy if I am dailing the DID number.
Just wanted to understand is it normal behavior?
