DTMF not working between 2 CUCM SIP Trunks
mohammad_omran
Dears
We have configured 2 SIP trunks on 2 CUCM servers , all calls are working fine except the DTMF ?? any ideas what can enable the DTMF between the SIP Trunks??
Inter-Cluster Trunk (Non-Gatekeeper Controlled) On Both Sides and the Codec is G.711u
Best Regards
13 Replies 13
Gajanan Pande
Enable MTP on the trunk & it will work.
GP.
Pls rate helpful posts by clicking on the stars below !!
Thanks for your reply , but i tried to enable MTP and didn't solve the case !! any ideas??
Could you explain the call flow & on which trunk the MTP was enabled ?
GP.
trying to call from first CUCM to the second CUCM
I tried to enable the MTP on the first one only ( where the call is orginated) didn't work
I tried to enable the MTP on the second one only ( where the call is terminated) didn't work
also on both didn't work !!
Please advise
So it appears that the call is between 2 CUCM Clusters connected with Non-GK Controlled ICT ( as mentioned in your intial post ). Where are these SIP trunks connecting to then ?
GP.
Both CUCM are publishers ( one only for employees and one for call Cener) ,each one has registered phones and we can call phones directly without problems , the only problem is when dialling the IVR hunt pilot which connected and gave us the welcome greetings but we can't select any options .
Ok, so as I understand following is the issue description.
There are 2 sites A & B. A has CUCM cluster for IPT users & Site B has CUCM Cluster for Contact Center users. These 2 clusters are connected using Non-GK controlled ICT.
Site A users when call Site B IVR, they hear the greeting but DTMF is not recognized hence they are unable to choose between options. Correct ?
1. What are the CUCM, IP IVR or UCCX/UCCE versions ?
2. Are the site B users able to choose options without any issues ?
3. When you said IVR, is it IPIVR/UCCX/CVP, Unity Connection, Unity, CUE or BACD on gateway ?
Please, always give full details of your setup & then ask the query, as it helps you only to get a quick & precise answers.
GP.
Pls rate helpful posts by clicking on stars below the post !!
Please Find my answers below :
Site A users when call Site B IVR, they hear the greeting but DTMF is not recognized hence they are unable to choose between options. Correct ? Correct
1. What are the CUCM, IP IVR or UCCX/UCCE versions ? CUCM for User 7.1.5.30000-1 , and for Call Center 8.0.3.20000-2 ,
2. Are the site B users able to choose options without any issues ?Yes
3. When you said IVR, is it IPIVR/UCCX/CVP, Unity Connection, Unity, CUE or BACD on gateway ?Media Server (CTIWEB)
also, please note that i have remote branc connected to the user Call manager and they can select IVR options ???
B.R
So looks like the Site A MTP resources are not enough ( falling short ) . What type of MTP resources are used at site A i.e. software or hardware ?
Are the MTP resources added properly in MRGL for the users who are accessing the IVR ? You might want to compare the site A user config with remote site user's config to see if you missed anything on MRGL part.
GP.
I am using software MTP , and the resource are available to the user , ( MTP is listed on the MRGL , and MRGL used by users ).
If it's Software MTP & the MRGL is properly configured with user device pools, then try restarting " Cisco IP Voice Media Streaming App " service on Site A CUCM Pub to see if it helps. After the service restart, try enabling MTP again, if it's disabled presently.
GP.
Same
as i mentioned before , we have remote branch connected to CUCM "A" and calls from that branch coming from PSTN can reach the IVR and DTMF worksfin with it . is there anything else that i can try??
Hi Mohammad,
I am having a similar problem. Did you get this issue resolved ? Can you help by providing your solution ? Thanks.
