207
Highlighted
Beginner
DX80 downgrade from CE to Android: Help !
Hello all,
Trying to downgrade my DX80 from CE 9.4 to Android, as I would like to use it as a "family terminal" (no CUCM)...
Anyone could help me, as it I read loads of litterature, but I can't find the right package as it seems:
dx80.ce8.2.0-syn213B.rel.pkg
Thanks inb advance
Dan
3 REPLIES 3
Highlighted
VIP Mentor
Re: DX80 downgrade from CE to Android: Help !
First, you need to downgrade your DX80 from CE9.x to CE8.2.x. The software, unfortunately, while still be visible on cisco.com's downloads, is deferred and cannot be obtained any longer.
https://software.cisco.com/download/home/286267306/type/282074288/release/CE8.2.2?releaseIndicator=DEFERRED
Note that you can run any 8.2.x version of CE code in order to be prepared to switch to android. It doesn't have to be a specific 8.2.x image.
After that, then that's when you need the synergy files in order to install the android OS. However, that is unlisted as well.
So, at this point, you can either open a TAC case, scour the internet, or hope someone private messages you some old files via dropbox or the like, because I think the official process is now dead.
Anthony Holloway
Highlighted
Beginner
Thanks very much for your answer !
That seems very clear now....
Go for "Hunting the lost files"....
Highlighted
VIP Mentor
I'm not saying I would have given them to you, but I can tell you straight up that I don't have them. Good luck on the hunt. You can try posting to the cisco voip mailing list @ https://puck.nether.net/mailman/listinfo/cisco-voip or the ciscoUC subreddit at https://www.reddit.com/r/ciscoUC/
Anthony Holloway
Content for Community-Ad
Cisco COVID-19 Survey
