03-04-2008 12:18 AM - edited 03-18-2019 08:33 PM
E1 0/0/0 is up.
Applique type is Channelized E1 - balanced
Description: DOD to International with PRI link
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20071009, FPGA: 20, spm_count = 0
Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (519 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
171 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
171 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 24 hours)
0 Line Code Violations, 0 Path Code Violations,
28557 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
28557 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
I can see a 171 slips error. is this ok? if not, how to fix this, whats the cause of this? thanks
03-04-2008 01:10 AM
basically, with my E1 module I have two ports connected to different Telco, can this contribute to "slip" error? any suggestions?
03-04-2008 02:57 AM
First of all, you need the network-clock-participate wic 0 and networkc-clock-select commands.
Then check again and let us know.
