1182
keanej
Participant
Emergency !! Major Power Failure - Publisher / Subscriber& Connection wont start...
We have had a major outage, after power restored Publisher services wont start.
In addition Unity connection has a corrupt database and another subscriber is screwed.
However - first things first - I desperately need to get my publisher live.
I have restarted it many times now -
The GUI doesnt work and at the command line when I type
utils services list -
they are all in [STARTING] -
Uptime is now 2 hours.
Any ideas ?? Hopefully someone is working on a saturday !
2 ACCEPTED SOLUTIONS
what version of call manager are we talking about here?
for best results...  you may want to get tac involved.
Jaime Valencia
Hall of Fame Cisco Employee
You should have involved your support team, TAC, or whoever that may be right away if this is an emergency, you cannot possibly expect the level of support required to fix something like this, and under time constrains, on a public forum. TAC is staffed 24x7 for this exact purpose.
Best I could tell you is to try the recovery CDs, or to restore from a backup, if all fails.
java
if this helps, please rate
8 REPLIES 8
keanej
Participant
I notice this bug
Services Stuck in Starting after Graceful Shutdown/Restart
CSCuj89245
Solution seems to be ..
Move selinux to permissive (utils os secure permissive)
Restart the server and then after services are up
Move selinux to enforcing (utils os secure enforce)
I'll try that and let you know how it goes  !
Well - that didnt work.
All services in [STARTING]
Any ideas ?
I just had a customer go through similar outage where all 4 subs at failed data center needed to be rebuilt per TAC, fortunately Pub was OK, so this was quick solution, you may need to rebuild the Pub and restore from good backup, but I concur with Java engage TAC as they have root access to analyze the issue.
Chris
Thanks for all the feedback -
I contacted TAC and raised a P1. We lost one publisher and one subscriber - we only had one working subscriber
we went down the road of SUB to PUB recovery.
At the end I downloaded the missing COP files and we were good to go.
The only 'gotcha' seems to be dial-plans - there were causing me a little heart ache and needed to be re-installed. Also MoH - but I didnt have much of that to begin with.
Apparently the underling Linux OS doesn't like sudden power downs !
FYI
My recovery disk was corrupt and a download of a fresh recovery disk fixed unity connection ! That was a relief !
Jaime Valencia
java
You can try to bring up the system using a recovery disk, however a rebuild may still be required as per the following doc
http://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/116717-trouble-cucm-shutdown-00.html
  • Cisco Bug ID CSCth60800, "Recovery Disc warning to rebuild system after file system repair"
  • Cisco Bug ID CSCth53322, "Document the need for system rebuild after file system repair"
Manish
Create
Recognize Your Peers
Content for Community-Ad
