Emergency Responder and LAN Switches
Scott Hanson
Level 3
Level 3
How can I go about finding the switches in CER that are associated with a particular site?
Thanks in advance!
Andrew Skelly
Level 7
Level 7
Assuming that the switches are discovered by CER you can go to ERL Membership - Switch Ports and search from there.  Search on either ERL name or by Switch IP Address.  When your results come up, click on View in the result row and it will open a popup window that shows the Switch HostName.
Please rate helpful posts by clicking the thumbs up!
Andrew Skelly
Level 7
Level 7
