Highlighted
Enthusiast
Export of Current Firmware on Devices
I did not see an option under exporting phone details, and I am looking for a report that lists all the devices with the firmware that is currently loaded on each of them.  Running CUCM 9.1.2.  Thanks!
1 ACCEPTED SOLUTION
Highlighted
You can run show risdb query phone on all the CM servers in the cluster to which phones are registered and then sort out the output in MS Excel and find the active FW load
http://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/118307-probsol-cucm-00.html
Deepak
5 REPLIES 5
Highlighted
"show tech devdefaults"  command will provide phone firmware defined in CUCM.
"show risdb query phone" command will provide phone firmware loaded on the phone.
Mohammed Noor
Highlighted
[+5] to Khan for sharing the command "show tech devdefaults" regds, aman
Highlighted
Advisor
hi ,
check this discussion
https://supportforums.cisco.com/discussion/12012036/how-know-firmware-version-all-devices-cucm-cluster
regds,
aman
Highlighted
Deepak
Highlighted
Enthusiast
Thank you everyone!
Content for Community-Ad
