01-26-2010 03:13 AM - edited 03-19-2019 12:21 AM
I have configured Extension Mobility in CUCM 6.1.2. Devices is enabled with EM and User Device profiles are created. The issue is that user is able to login to the phone successfully and i can see the profile logged in device on the web of configuration device. The phone comes back normal but without the DN configured for the user. When Services button is pressed i can log off the user, the other services are also listed out.I reboot the extension mobility service and also TFTP service.
Wondering where the problem could be. Any help is highly appreciated. thanks.
thank's in adavance.
01-26-2010 09:00 AM
Did you associate the Directory Number to the Device Profile?
01-26-2010 09:11 AM
Yes of course.
The problem is affecting more then 20 uers, and it works before.
does anyone has been already faced this problem with this version fo CUCM 6.1.2 ?
04-13-2010 02:31 AM
I am having the same problem with the same version. Did you find a fix / bug for this problem?
04-13-2010 02:50 AM
May be screen grab your device profile/DN/phone button template config screens... and post them up.
Aaron
