I have CUCM version 7.1.3. all users have the extension mobility service to log on and all users forced to log out after 8 hours from log on .This feature is applied to some users but not for others
For example:
User A use extension mobility service to log on at 10:00 AM
- In Normal Case -------> User A forced log out after 8 hours from log on time (Some Users)
- In Abnormal Case ----> User A never log out automatic after 8 hours from log on (another some)
If any one has solution for this problem please send it to me .
Very Thanks,
Solved! Go to Solution.
1/ have you changed the forced logout parameter after users were logged in? They will not be logged out..
2/ have you restarted the EM service? All logged in users will not be logged out...
I recommend;
- force logout all users (there are different ways to do this)
- restart em service(s)
then all users that login will have the forced logout timer applied correctly (until you restart the em service ;-)
As you probably know , the force logout is a CCM parameter , not configured based on users.
Are you saying that the same user sometimes the system make a forced logout and sometimes not ?
Amer
I know force logout is CUCM service parmeter but the system make some users forced to logout and some not
Many Thanks ,
It looks like it is a service problem , did you try to restart the tomcat and extension mobility service from the servicability?
did you check the RTMT for errors ?
try the above and let us know
Amer
Dear Amer ,
Many thanks for your care .i will try tomorrow and i will let you know
I recommend;
hi,
many tanks for your solution . i forced log all user after that the forced logout timer applied correctly
thanks.
