Extension Mobility Timeout Per Phone?
steigja
Level 3
Level 3
Is there anyway in CUCM 7.1.3 to set a particular phone to not have an extension mobility logout timer, different from the settings in the service parameters?  Are all extension mobility logout settings global?  thanks
Global parameter.  Applies cluster-wide to all EM-enabled phones.
Hailey
6 Replies 6
Jaime Valencia
We have no built-in mechanish to do this per phone, the logout setting is for all EM users
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Hailey
Hi David / Java,
Old thread but I thought I would give it a try.  I need to mod this EM Servive Parameter.  Is it service impacting to any existing users who are logged in via EM?
TIA,
Amir
No, but changes will only affect phones that log in AFTER you change the value.
Phones that were logged before, will not take that change.
java
java
Hi Java,
Could you please point me where I can find that " Global parameter.  Applies cluster-wide to all EM-enabled phones."
Hi there,
You will find those settings via;
To set the Service Parameters for Cisco Extension Mobility, choose
System > Service Parameters in Cisco  Unified Communications Manager Administration;
choose the server that  is running the Cisco Extension Mobility service, and then  Cisco Extension Mobility
Cheers!
Rob
"A smile relieves a heart that grieves"
- Stones
