Highlighted
FAX over E1 Pr1 line problem
Hello:
I have the next diagram implemented.......
PSTN ---------- E1/PRI--------GW1--------CUCM----------GW1--------FXS-------Fax
I have a fax phone connected to a FXS port in my gateway GW1 whom is runned by the CUCM.......i configured a DID number that is coming to the same gateway GW1 via a E1/PRI line........my problem is that the fax can send faxes but it cant recieve anyone.....i dont know what could be the problem????? could anyone please give me any pointers!!!!
Best Regards
Everyone's tags (6)
1 ACCEPTED SOLUTION
Highlighted
Rising star
Re: FAX over E1 Pr1 line problem
Bruno,
I recommend you also post this to the Cisco Support Community for additional feedback and information from technical experts.
https://supportforums.cisco.com/
I hope this helps.
Kelli Glass
Moderator for Cisco Customer Communities
2 REPLIES 2
Highlighted
Rising star
Bruno,
I hope this helps.
Kelli Glass
Highlighted
Beginner
hi Bruno,
Hope you might have already fixed it.
you can do two things,
I am assume that FXS port connected to CUCM as MGCP.
1. This scenario CUCM will decide the routing the calls through CSS what is built on DP.
2. Take a simple analog phone connect to FXS line and make sure you have both incoming / outgoing if that works fine I expect it to work fine.
3. Check for t.38 or Modem Pass-through enabled on the GW or CUCM GW page.
