Walkthrough Wednesdays
436
ChrisYoakem6083
Beginner
Finding a called number's incoming voice gateway.
Hi All,
I keep going round and round with debugs and I'm stuck on what I thought would be a simple find.
I'm going through data collection for my company and I am stuck trying to find a dialed number's voice gateway.
Simply put: If I dial 123-456-7890 from an outside line into my organization how can I find which voice gateway this number comes in on if we have several VGWs we're dealing with?
Thanks for the assistance!
1 ACCEPTED SOLUTION
joshua.gertig
Beginner
I'd try looking in RTMT, under "Real Time Data". Limit your search to *1234567890*. In the column "Calling Device Name" you should see the GW name there. If you don't have RTMT, I'd suggest looking in CDR (Unified Serviceability) Tools - CDR Analysys. Should see it there too.
3 REPLIES 3
joshua.gertig
Beginner
That's exactly what I needed thank you Joshua!
Jaime Valencia
Hall of Fame Cisco Employee
Have you reached out to your telco for that info?
java
if this helps, please rate
Content for Community-Ad
Spotlight Awards 2021
