Forwarding Calls to a Call Handler
trgriffin
I have a question regarding forwarding extensions to an information line.
I have several departments (library, hr for example) who want to forward their main number to their information lines when no one will be available to answer the phone or after they are closed.  The information line is setup in Unity as a system call handler (with it's own DID) that normally just gives information.  When I try to forward my phone to one of these and then call it, the call goes to my voice mailbox instead.
Anyone else have this issue?
Tonya
Jaime Valencia
That's WAD. You would need to configure a call routing rule to handle this calls.
The other option is to change the config to use the last redirecting number but this is a global change, meaning all calls will only use the last redirecting number to determine which mailbox or CH to reach.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
I've found the call routing rules section in Unity.  But since I have no training on this system I can't quite figure out the logic.  Do you know of a good resource I can use?
The easiest way to get the grip of this is to use the call viewer, if Unity look in the tools depot.
If CUC you can download it from http://www.ciscounitytools.com/
Play a little bit with it and see what you get from a direct call and what from a FW call, you'll see what changed and that's exactly what you need to configure the call routing rule to match with.
java
java
