Highlighted
Beginner
[Help] Ldap Sync 0 results.
I have CUCM (11.5) configured to my own LDAP server.
I created LDAP server to pull data from mongoDB instead of AD (for specific reasons).
when trying to sync i receive the following error in the logs (which i cannot attach due to CUCM living in offline system):
LDAPSync(<some uuid>) Failed to check LDAP - javax.naming.NameNotFoundException: [LDAP: error code 32 - No tree found for: ]; remaining name ''
From the logs it seems it is sending an empty DN
BUT
On my server i do see the DN  it is sending and the server is responding with sending the entries
When trying to search data from the server manually with linux 'ldapsearch' tool i do get the entries..
example from test of ldapsearch:
any suggestions ?
3 REPLIES 3
Highlighted
Advocate
CUCM has support for these LDAP servers.
Microsoft Active Directory
Microsoft Active Directory Application Mode (ADAM) or Active Directory Lightweight Directory Service (AD LDS)
Oracle DSEE and Sun
OpenLDAP and Other LDAPv3 Types
Please rate all useful posts
Highlighted
I’m in the last category, although I have 4 other directories which are
Microsoft AD. Is it possible to set this server as “other” and the other 4
as Microsoft AD?
Highlighted
I’m in the last category, although I have 4 other directories which are Microsoft AD. Is it possible to set this server as “other” and the other 4 as Microsoft AD?
Content for Community-Ad
