Documentation is pretty clear on this, you need to provide the required specs for each deployment size AND the RAM, CPU and NIC reservations as stated in the installation guide.
There should be no problem if they deploy and then update the VM version, but resource reservation as per documentation is mandatory.
Failure to do so, means the deployment will NOT be supported by Cisco.
java
if this helps, please rate
