hankej
Beginner
How to see if calls are reaching Cube from Outside
So I have a SIP trunk created to connect my CUCM environment to a Poly environment.  I am using a 10 digit extension, which is a DID number,  on the Poly endpoints and have created some route points in CUCM. I am pointing the route points to the SIP trunk.  Internally I can dial the number and it does appear to be connected to the Poly end.  However, when I call the number from my cell phone I get the message "The number you dialed is not a working number.  Please check the number and dial again".
When I use the Directory number analyzer, it looks like it should be routing.
So I'm curious to see if my call from the cell phone is making it to my cube.  Any ideas how I can see if it is?
Thank you.
1 ACCEPTED SOLUTION
Roger Kallberg
VIP Advisor
Do a debug ccsip message
Please rate all useful posts
1 REPLY 1
Roger Kallberg
VIP Advisor
Content for Community-Ad
Spotlight Awards 2021
