06-17-2015 07:28 AM - edited 03-19-2019 09:42 AM
I'm trying to install the IM & Presence version 10.5.(2) and getting the following error message after the installation.
" A Cisco DB may have encountered a known issue - If services are not starting please run 'utils service restart Service Manager'"
Do you have any idea how to fix that?
06-17-2015 06:54 PM
Hi Jefferson,
Is it the first node in the IM&P cluster?
Are the correct specs configured as per OVA guidelines below?
http://docwiki.cisco.com/wiki/Virtualization_for_Unified_CM_IM_and_Presence
Please ensure the NTP server is working correctly and reachable from IM&P server.
Manish
03-30-2017 11:55 AM
Hi Manish,
Thank you for your tip. I faced up the same db issue and the solution was to set up correctly the NTP.
04-20-2016 01:44 AM
Hi Jeff,
I am having same issue and encountered same error when I am trying to login to IMP via CLI.
Please let me know what was the issue and how it got fixed.
08-18-2016 01:39 PM
I am getting this message sometimes when access the cli.
checked and all services are started ok
ntp & dns all good
built using a good md5 checked ova also
Did you get a fix or indication of what is causing this?
Neil
08-19-2016 03:30 AM
this error message generally comes when server is unable to read its own database for some reason. if anything is wrong in database then services refuse to start. i suggest you to check your db replication for cups cluster.
08-25-2016 08:46 AM
I have a single cucm & single imp and repl was all good.
i did a clean shutdown and power on and all came up ok.
i also installed the vmtools.cop.sgn file but they still not register as installed, so think a clean buil may be in order.
Thanks for confirming what it does though.
Neil
