ā10-23-2020 11:53 PM
any help me,
i have case integration cucm and cisco 2911 and status "Registered with 114.28.23.8", but MGCP port fxo is "device not Trusted" in cucm.
INDOVGW01#show ccm-manager
MGCP Domain Name: INDOVGW01
Priority Status Host
Primary Registered 114.28.23.8
First Backup None
Second Backup None
Current active Call Manager: 114.28.23.8
Backhaul/Redundant link port: 2428
Failover Interval: 30 seconds
Keepalive Interval: 15 seconds
Last keepalive sent: 05:37:40 UTC Oct 24 2020 (elapsed time: 00:00:03)
Last MGCP traffic time: 05:37:40 UTC Oct 24 2020 (elapsed time: 00:00:03)
Last failover time: None
Last switchback time: None
Switchback mode: Graceful
MGCP Fallback mode: Enabled/OFF
Last MGCP Fallback start time: 10:36:00 UTC Oct 23 2020
Last MGCP Fallback end time: 10:36:42 UTC Oct 23 2020
MGCP Download Tones: Disabled
TFTP retry count to shut Ports: 2
FAX mode: disable
Configuration Error History:
isdn switch-type primary-4ess
end
INDOVGW01#show mg
INDOVGW01#show mgcp
MGCP Admin State ACTIVE, Oper State ACTIVE - Cause Code NONE
MGCP call-agent: 114.28.23.8 2427 Initial protocol service is MGCP 0.1
MGCP validate call-agent source-ipaddr DISABLED
MGCP validate domain name DISABLED
MGCP block-newcalls DISABLED
MGCP send SGCP RSIP: forced/restart/graceful/disconnected DISABLED
MGCP quarantine mode discard/step
MGCP quarantine of persistent events is ENABLED
MGCP dtmf-relay voip codec all mode out-of-band
MGCP dtmf-relay for voAAL2 is SDP controlled
MGCP voip modem passthrough mode: NSE, codec: g711ulaw, redundancy: DISABLED,
MGCP voaal2 modem passthrough disabled
MGCP voip modem relay: Disabled
MGCP T.38 Named Signalling Event (NSE) response timer: 200
MGCP Network (IP/AAL2) Continuity Test timer: 200
MGCP 'RTP stream loss' timer disabled
MGCP request timeout 500
MGCP maximum exponential request timeout 4000
MGCP rtp unreachable timeout 1000 action notify
MGCP gateway port: 2427, MGCP maximum waiting delay 3000
MGCP restart delay 0, MGCP vad DISABLED
MGCP rtrcac DISABLED
MGCP system resource check DISABLED
MGCP xpc-codec: DISABLED, MGCP persistent hookflash: DISABLED
MGCP persistent offhook: ENABLED, MGCP persistent onhook: DISABLED
MGCP piggyback msg ENABLED, MGCP endpoint offset DISABLED
MGCP simple-sdp ENABLED
MGCP undotted-notation DISABLED
MGCP codec type g711ulaw, MGCP packetization period 20
MGCP JB threshold lwm 30, MGCP JB threshold hwm 150
MGCP LAT threshold lwm 150, MGCP LAT threshold hwm 300
MGCP PL threshold lwm 1000, MGCP PL threshold hwm 10000
MGCP CL threshold lwm 1000, MGCP CL threshold hwm 10000
MGCP playout mode is adaptive 60, 40, 1000 in msec
MGCP Fax Playout Buffer is 300 in msec
MGCP media (RTP) dscp: ef, MGCP signaling dscp: af31
MGCP default package: trunk-package
MGCP supported packages: gm-package dtmf-package trunk-package line-package
hs-package rtp-package atm-package ms-package dt-package
mo-package mt-package sst-package fxr-package pre-package
md-package
MGCP Digit Map matching order: shortest match
SGCP Digit Map matching order: always left-to-right
MGCP VoAAL2 ignore-lco-codec DISABLED
MGCP T.38 Max Fax Rate is DEFAULT
MGCP T.38 Fax is DISABLED
MGCP T.38 Fax ECM is DISABLED
MGCP T.38 Fax NSF Override is DISABLED
MGCP T.38 Fax Low Speed Redundancy: 0
MGCP T.38 Fax High Speed Redundancy: 0
MGCP Fax relay SG3-to-G3: ENABLED
MGCP Fax relay ANSam suppression: DISABLED
MGCP control bind :DISABLED
MGCP media bind :DISABLED
MGCP Upspeed payload type for G711ulaw: 0, G711alaw: 8
MGCP Dynamic payload type for Cisco fax indication: 96, Cisco fax ack: 97
MGCP Dynamic payload type for G.726-16K codec
MGCP Dynamic payload type for G.726-24K codec
MGCP Dynamic payload type for G.726-32K codec
MGCP Dynamic payload type for G.Clear codec
MGCP Dynamic payload type for NSE is 100
MGCP Dynamic payload type for NTE is 99
MGCP rsip-range is enabled for TGCP only.
MGCP Comedia role is NONE
MGCP Comedia check media source is DISABLED
MGCP Comedia SDP force is DISABLED
MGCP g729 variants use static payload type and contain annexb in SDP
MGCP Guaranteed scheduler time is DISABLED
MGCP Disconnect delay error recovery DISABLED
MGCP DNS stale threshold is 30 seconds
Shouldnt the CUCM say that the device is trusted since this is an MGCP connection?
I would appreciate if you can help me!
Solved! Go to Solution.
ā10-24-2020 01:57 AM
AFAIK this is expected. Itās the same with SCCP controlled analog ports. AFAIK it would not have any effect on functionality.
ā11-01-2020 01:23 AM
ā11-01-2020 01:24 AM
Thanks Nithin, now i can make call incoming and outgoing call
Thanks Roger, now i can make call incoming and outgoing call
ā10-24-2020 06:20 AM - edited ā10-24-2020 06:20 AM
This is quite normal.
"device not Trusted" That means those endpoints don't support the full security of authentication and encryption that other Cisco model phones do.
Do you face any problems ?
