Hi All,
Inbound calls to my gateway are not working. I ran a debug Q931 and receive an error: Cause i = 0x8083 - No route to destination
I've checked the SIP binding, significant digits on gateway has been set to 'All'. Inbound CSS is set in accordance with the phones. Any ideas would be appreciated. Outbound calls work fine:
Debug as follows. I have also included the gateway configuration below the debug.
*Jul 26 12:52:15.734: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8 callref = 0x33
Sending Complete
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x81
Preferred, B1
Progress Ind i = 0x8483 - Origination address is non-ISDN
Calling Party Number i = 0x0180, '00447741633020'
Plan:ISDN, Type:Unknown
Calling Party Number i = 0x0183, '00447741633020'
Called Party Number i = 0xA1, '45902867'
Plan:ISDN, Type:National
*Jul 26 12:52:15.750: ISDN BR0/1/0 Q931: TX -> CALL_PROC pd = 8 callref = 0xB3
Channel ID i = 0x89
Exclusive, B1
*Jul 26 12:52:15.770: ISDN BR0/1/0 Q931: TX -> DISCONNECT pd = 8 callref = 0xB3
*Jul 26 12:52:15.870: ISDN BR0/1/0 Q931: RX <- RELEASE pd = 8 callref = 0x33
*Jul 26 12:52:15.870: ISDN BR0/1/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xB3
*Jul 26 12:52:17.150: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8 callref = 0x32
Sending Complete
Standard = CCITT
Channel ID i = 0x81
Preferred, B1
*Jul 26 12:52:17.166: ISDN BR0/1/0 Q931: TX -> CALL_PROC pd = 8 callref = 0xB2
Channel ID i = 0x89
Exclusive, B1
*Jul 26 12:52:17.182: ISDN BR0/1/0 Q931: TX -> DISCONNECT pd = 8 callref = 0xB2
*Jul 26 12:52:17.294: ISDN BR0/1/0 Q931: RX <- RELEASE pd = 8 callref = 0x32
*Jul 26 12:52:17.298: ISDN BR0/1/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xB2
*Jul 26 12:52:18.534: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8 callref = 0x31
Sending Complete
Standard = CCITT
Channel ID i = 0x81
Preferred, B1
*Jul 26 12:52:18.550: ISDN BR0/1/0 Q931: TX -> CALL_PROC pd = 8 callref = 0xB1
Channel ID i = 0x89
Exclusive, B1
*Jul 26 12:52:18.570: ISDN BR0/1/0 Q931: TX -> DISCONNECT pd = 8 callref = 0xB1
*Jul 26 12:52:18.662: ISDN BR0/1/0 Q931: RX <- RELEASE pd = 8 callref = 0x31
*Jul 26 12:52:18.666: ISDN BR0/1/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xB1
*Jul 26 12:52:19.994: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8 callref = 0x30
Sending Complete
Standard = CCITT
Channel ID i = 0x81
Preferred, B1
*Jul 26 12:52:20.010: ISDN BR0/1/0 Q931: TX -> CALL_PROC pd = 8 callref = 0xB0
Channel ID i = 0x89
Exclusive, B1
*Jul 26 12:52:20.026: ISDN BR0/1/0 Q931: TX -> DISCONNECT pd = 8 callref = 0xB0
*Jul 26 12:52:20.142: ISDN BR0/1/0 Q931: RX <- RELEASE pd = 8 callref = 0x30
*Jul 26 12:52:20.142: ISDN BR0/1/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xB0
*Jul 26 12:52:21.450: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8 callref = 0x2F
Sending Complete
Standard = CCITT
Channel ID i = 0x81
Preferred, B1
*Jul 26 12:52:21.466: ISDN BR0/1/0 Q931: TX -> CALL_PROC pd = 8 callref = 0xAF
Channel ID i = 0x89
Exclusive, B1
*Jul 26 12:52:21.482: ISDN BR0/1/0 Q931: TX -> DISCONNECT pd = 8 callref = 0xAF
*Jul 26 12:52:21.590: ISDN BR0/1/0 Q931: RX <- RELEASE pd = 8 callref = 0x2F
*Jul 26 12:52:21.590: ISDN BR0/1/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xAF
*Jul 26 12:52:22.942: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8 callref = 0x2E
Sending Complete
Standard = CCITT
Channel ID i = 0x81
Preferred, B1
*Jul 26 12:52:22.962: ISDN BR0/1/0 Q931: TX -> CALL_PROC pd = 8 callref = 0xAE
Channel ID i = 0x89
Exclusive, B1
*Jul 26 12:52:22.978: ISDN BR0/1/0 Q931: TX -> DISCONNECT pd = 8 callref = 0xAE
*Jul 26 12:52:23.086: ISDN BR0/1/0 Q931: RX <- RELEASE pd = 8 callref = 0x2E
*Jul 26 12:52:23.090: ISDN BR0/1/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xAE
*Jul 26 12:52:24.234: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8 callref = 0x2D
Sending Complete
Standard = CCITT
Channel ID i = 0x81
Preferred, B1
*Jul 26 12:52:24.254: ISDN BR0/1/0 Q931: TX -> CALL_PROC pd = 8 callref = 0xAD
Channel ID i = 0x89
Exclusive, B1
*Jul 26 12:52:24.270: ISDN BR0/1/0 Q931: TX -> DISCONNECT pd = 8 callref = 0xAD
*Jul 26 12:52:24.374: ISDN BR0/1/0 Q931: RX <- RELEASE pd = 8 callref = 0x2D
*Jul 26 12:52:24.374: ISDN BR0/1/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xAD
*Jul 26 12:52:25.990: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8 callref = 0x2C
Sending Complete
Standard = CCITT
Channel ID i = 0x81
Preferred, B1
*Jul 26 12:52:26.006: ISDN BR0/1/0 Q931: TX -> CALL_PROC pd = 8 callref = 0xAC
Channel ID i = 0x89
Exclusive, B1
*Jul 26 12:52:26.022: ISDN BR0/1/0 Q931: TX -> DISCONNECT pd = 8 callref = 0xAC
*Jul 26 12:52:26.134: ISDN BR0/1/0 Q931: RX <- RELEASE pd = 8 callref = 0x2C
*Jul 26 12:52:26.138: ISDN BR0/1/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xAC
*Jul 26 12:52:27.226: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8 callref = 0x2B
Sending Complete
Standard = CCITT
Channel ID i = 0x81
Preferred, B1
*Jul 26 12:52:27.242: ISDN BR0/1/0 Q931: TX -> CALL_PROC pd = 8 callref = 0xAB
Channel ID i = 0x89
Exclusive, B1
*Jul 26 12:52:27.262: ISDN BR0/1/0 Q931: TX -> DISCONNECT pd = 8 callref = 0xAB
*Jul 26 12:52:27.362: ISDN BR0/1/0 Q931: RX <- RELEASE pd = 8 callref = 0x2B
*Jul 26 12:52:27.362: ISDN BR0/1/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xAB
*Jul 26 12:52:28.542: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8 callref = 0x2A
Sending Complete
Standard = CCITT
Channel ID i = 0x81
Preferred, B1
*Jul 26 12:52:28.558: ISDN BR0/1/0 Q931: TX -> CALL_PROC pd = 8 callref = 0xAA
Channel ID i = 0x89
Exclusive, B1
*Jul 26 12:52:28.574: ISDN BR0/1/0 Q931: TX -> DISCONNECT pd = 8 callref = 0xAA
*Jul 26 12:52:28.682: ISDN BR0/1/0 Q931: RX <- RELEASE pd = 8 callref = 0x2A
*Jul 26 12:52:28.686: ISDN BR0/1/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xAA
*Jul 26 12:52:29.858: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8 callref = 0x29
Sending Complete
Standard = CCITT
Channel ID i = 0x81
Preferred, B1
*Jul 26 12:52:29.874: ISDN BR0/1/0 Q931: TX -> CALL_PROC pd = 8 callref = 0xA9
Channel ID i = 0x89
Exclusive, B1
*Jul 26 12:52:29.890: ISDN BR0/1/0 Q931: TX -> DISCONNECT pd = 8 callref = 0xA9
*Jul 26 12:52:29.990: ISDN BR0/1/0 Q931: RX <- RELEASE pd = 8 callref = 0x29
*Jul 26 12:52:29.994: ISDN BR0/1/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xA9
*Jul 26 12:52:30.566: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8 callref = 0x28
Sending Complete
Standard = CCITT
Channel ID i = 0x81
Preferred, B1
Plan:ISDN, Type:National..........................
Gateway config:
hostname XXXXXXXXXXXXX
boot-start-marker
boot system flash c1861-spservicesk9-mz.152-4.M10.bin
boot-end-marker
enable secret 5 XXXXXXXXXXXXXXXXXXXXX
no aaa new-model
clock timezone CET 1 0
clock summer-time CEST recurring
network-clock-participate wic 1
network-clock-participate wic 2
network-clock-select 1 BRI0/1/0
network-clock-select 2 BRI0/1/1
network-clock-select 3 BRI0/2/0
network-clock-select 4 BRI0/2/1
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
dot11 syslog
ip domain name nsanet.local
ip cef
no ipv6 cef
isdn switch-type basic-net3
--More-- !
trunk group BRI
voice service voip
ip address trusted list
ipv4 10.X.X.X 255.255.255.0
ipv4 10.X.X.X 255.255.0.0
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
bind control source-interface Vlan1
bind media source-interface Vlan1
registrar server expires max 120 min 60
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
--More-- !
voice translation-rule 1
rule 1 /\(^.+\)/ /+\1/ type international international
rule 2 /\(^.+\)/ /+45\1/ type national national
rule 3 /^00\(.+\)/ /+\1/ type unknown unknown
rule 4 /^0\(.+\)/ /+45\1/ type unknown unknown
voice translation-rule 2
rule 1 /^459028\(..\)/ /816\1/
rule 14 /^45829501/ /89616010101/
rule 15 /^45829503/ /81613/
voice translation-rule 3
rule 15 /^816\(..\)/ /4589883142/
voice translation-rule 4
rule 1 /^\+45\(.+\)/ /\1/
rule 2 /^\+\(.+\)/ /00\1/
voice translation-rule 11
rule 1 /^\([1-9].\)/ /816\0/
voice translation-profile IN
translate calling 1
translate called 2
voice translation-profile OUT
translate calling 3
translate called 4
voice translation-profile SRST
translate called 11
voice-card 0
dspfarm
dsp services dspfarm
license udi pid C1861E-SRST-B/K9 sn FCZ1705C59N
username admin privilege 15 secret 5 $1$evxw$0x7DcgnU9hOuUMOEMetz00
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1/0
no ip address
interface FastEthernet0/1/1
no ip address
interface FastEthernet0/1/2
no ip address
interface FastEthernet0/1/3
no ip address
interface FastEthernet0/1/4
no ip address
interface FastEthernet0/1/5
no ip address
interface FastEthernet0/1/6
no ip address
interface FastEthernet0/1/7
no ip address
interface FastEthernet0/1/8
no ip address
interface BRI0/1/0
no ip address
isdn point-to-point-setup
isdn incoming-voice voice
isdn sending-complete
isdn static-tei 0
trunk-group BRI
interface BRI0/1/1
no ip address
shutdown
isdn static-tei 0
trunk-group BRI
interface BRI0/2/0
no ip address
shutdown
isdn static-tei 0
trunk-group BRI
interface BRI0/2/1
no ip address
shutdown
isdn static-tei 0
trunk-group BRI
interface Vlan1
ip address 10.X.X.X 255.255.255.0
ip default-gateway 10.X.X.X
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.X.X.X
snmp-server community XXXXXXXXX RO
control-plane
voice-port 0/0/0
station-id name Denmark FAX
station-id number 81613
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
translation-profile outgoing OUT
compand-type a-law
cptone DK
bearer-cap 3100Hz
voice-port 0/1/1
compand-type a-law
cptone DK
bearer-cap 3100Hz
voice-port 0/2/0
compand-type a-law
cptone DK
bearer-cap 3100Hz
voice-port 0/2/1
compand-type a-law
cptone DK
bearer-cap 3100Hz
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control
description Music On Hold Port
--More-- !
mgcp profile default
dial-peer voice 1 pots
description INCOMING BRI
translation-profile incoming IN
incoming called-number [1-9]T
direct-inward-dial
dial-peer voice 10 pots
trunkgroup BRI
description PSTN OUT
preference 1
destination-pattern 0T
progress_ind alert enable 8
dial-peer voice 11 pots
trunkgroup BRI
destination-pattern +T
dial-peer voice 20 voip
description VOIP zum PUB
preference 1
destination-pattern 8....
modem passthrough nse codec g711ulaw
session protocol sipv2
session target ipv4:10.X.X.X
voice-class codec 1
voice-class sip options-keepalive
dtmf-relay rtp-nte
ip qos dscp cs3 signaling
no vad
dial-peer voice 21 voip
description VOIP zum SUB
preference 2
--More-- voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 8613 pots
destination-pattern 81613
port 0/0/0
no dial-peer outbound status-check pots
gateway
media-inactivity-criteria all
timer receive-rtcp 4
timer receive-rtp 1200
sip-ua
no remote-party-id
call-manager-fallback
secondary-dialtone 0
--More-- max-conferences 4 gain -6
transfer-system full-consult
ip source-address 10.X.X.X port 2000
max-ephones 12
max-dn 48 dual-line
system message primary SRST Backup-Service
transfer-pattern .T
alias 1 81660 to 81661
alias 2 81660 to 81662
alias 3 81660 to 81663
alias 4 81660 to 81664
alias 5 81660 to 81665
alias 6 81660 to 81666
alias 7 81660 to 81667
alias 8 81660 to 81668
alias 9 81660 to 81669
translation-profile incoming SRST
call-forward pattern .T
moh "NSA_MOH.wav"
time-format 24
date-format dd-mm-yy
--More-- line con 0
no modem enable
line aux 0
line vty 0 4
exec-timeout 120 0
logging synchronous
login local
transport input all
line vty 5 15
logging synchronous
login local
transport input all
ntp server 10.X.X.X
end
VG_XXXXXXXX# exit
Solved! Go to Solution.
Old router. Required a reboot and it's fixed the issue : )
