04-16-2021 02:47 PM
Hello all,
I nedd your help please !
I have a cucm 12.5 integrated with VG-323 with protocol SCCP. all work fine , but i can't see the name of caller when i have a incoming call on analog phone.
Could you help me please ?
Best regards
Akram
04-16-2021 03:14 PM
Hi Akram,
Is this incoming calls are internal or external call ?
having issue all incoming calls or any specific ?
04-17-2021 03:27 AM
Hi , for internal call.
04-16-2021 11:07 PM - edited 04-16-2021 11:08 PM
The analogue phone which you use, Does it support displaying caller-Name ?
Commonly seen Analogue phones display only caller Number.
04-17-2021 03:30 AM
Hi , this analog phone support displaying caller-name.
for more detail i would like to see the caller name for internal call not external call , is that possible ?
Best regards
04-17-2021 03:39 AM
See the below link for your reference.
If this answered your question, please click "ACCEPT AS SOLUTION"<<<=
=>>>If you find this response useful, please mark it as "HELPFUL
04-17-2021 05:36 AM
What you Mean by VG-323, AFAIK there is no VG 323 model available from Cisco.
Since the FXS ports are configured as SCCP the configuration are same as a normal IP phone in CUCM. if the analogue phones support it should display the caller name. I have hotels running on VG with analogue phones but all are without Display..
The document other member shared is not related your scenario.
04-17-2021 07:38 PM
Administrator activates on the Cisco call-control system. Time stamp is from the Cisco voice gateway. Note To display the caller ID when caller ID is supported by the local telco provider, an administrator must use the caller id enable command on the appropriate Cisco voice gateway port. |
For feature information, see the “Caller Identification and Restriction” section of the “Understanding Route Plans” chapter under “Dial Plan Architecture” in the Cisco Unified Communications Manager System Guid e. For caller-ID display on local calls (calls between FXS ports and IP phones registered to the same Cisco Unified CME router):
For restricting or blocking caller-ID display:
