05-05-2021 08:39 AM
Helle all,
I have a cucm 12.5 registered with voice gateway ISR321 on H.323 , in this gateway i have 4 BRI .
the problem that i have , some externals number can't call my BRI (incoming call) , just a call in the void. you find bellow the example debug of this issue.
While the others externals numbers can call my BRI.
Could you please help me to solve this issue?
Best regards
Solved! Go to Solution.
05-06-2021 05:33 AM
The problem is solved after deactivate : "Reject Anonymous Calls" on Directory number.
Best regards
05-05-2021 09:30 AM
On your debug file ISDN status shows State = TEI_ASSIGNED, if the lines are UP it should be multiple frames established.
05-05-2021 10:24 AM
Thank you Nithin for your reply, when the line is on call state it switch to multiple frames established .
Best regards
05-05-2021 11:42 AM
If you check the all debug you can find this cuase : Cause Value=21, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=21)
what that is mean ?
for more information , the issue appear just for certain external calls ,not all.
Best regards
05-05-2021 11:51 AM - edited 05-05-2021 11:52 AM
This cause code indicates that the call is rejected.
05-05-2021 12:02 PM
Thank you for your reply , what can i do to solve this issue . this issue is just on incoming call for certain external calls.
Best regards
05-05-2021 12:33 PM - edited 05-05-2021 01:26 PM
You would need to look at the debug output to see for what reason the calls are rejected.
These debugs would be applicable.
If you post the output of these we can probably help you out.
05-06-2021 02:36 AM
05-06-2021 03:09 AM - edited 05-06-2021 03:22 AM
It could help if you where to share some details of the failed call, for instance the calling and called numbers.
05-06-2021 03:16 AM - edited 05-06-2021 06:15 AM
So the called seems to be translated from 0537755040 to 555 and then it matches dial-peer 5 and 6. Assuming that these are the dial-peers that points towards CM? Would you mind sharing the running config of the gateway also? For the calling number part it is set as hidden by the 0x00A3 tag in ISDN signaling.
May 6 08:20:30.418: ISDN BR0/2/0:0 Q931: RX <- SETUP pd = 8 callref = 0x75
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x89
Exclusive, B1
Calling Party Number i = 0x00A3, N/A
Plan:Unknown, Type:Unknown
Called Party Number i = 0x81, '0537755040'
Plan:ISDN, Type:Unknown
05-06-2021 04:40 AM
Thank you for your repy, after a test i find that the problem become for certain incoming external calls to IP phone 8851 .
But it's work fine on IP phone 7821.
Best regards
05-06-2021 12:11 AM
As @Roger Kallberg mentioned, Cause Value=21 is call rejected.
When calling from outside Does this happen for few internal numbers or its common for all internal number ?
05-06-2021 02:37 AM
Both, that it's happen for certain external calls not all
05-06-2021 04:35 AM
For more information after test i find this problem for certain incoming external calls not work on cisco 8851 , but it’s worked on cisco 7821.
Best regards
05-06-2021 05:33 AM
Best regards
