I have 2 IP phones 7940's connected to a C1760 router configured with 2xFXS ports and 2x FXO ports running CME v4.1
The 2 phones can each complete a successful outgoing call over the pstn line. When an INCOMING call is being received the caller hears one ring and nothing else?
Solved! Go to Solution.
Looks like you are missing dial-peers on the POTS lines to accept inbound calls. Example:
dial-peer voice pots 100
direct-inward-dial
incoming called-number .T
port 1/0
direct-inward-dial
port 1/1
This assumes you don't require translations to get to extension 1000 and 1001.
HTH.
Bill
Config ?
direct-inward-dial
port 1/0
direct-inward-dial
port 1/1
HTH.
Bill
I was being a bit dim and not reading the CCNA Voice guide
Page 271 of the Cisco Press guide:-
When an incoming signal is detected CME doesn't know what to do with it unless you specify a PLAR (Private Line Automatic Ringdown)
config:-
voice-port 1/0
cp-tone GB
connection plar 1000
voice-port 1/1
cp-tone GB
With this config any of the 2 ports connected with a standard PSTN phone line will be forwarded instantly to x1000 i.e a receptionist if you can afford one!
Another important note is the cp-tone to the correct country otherwise the incoming caller knows they have dropped on a call system.
All I have to work out now is a timeout, if the incoming call is closed x1000 keeps ringing for approx 2 minutes
thanks
Steven
