07-08-2013 11:45 AM - edited 03-19-2019 06:58 AM
When a User try to leave a message, unity play the name user in English. The name user should be played by unity in Spanish
Unity Connection 8.5.1.10000.206
Language : Spanish (Colombia).
Sombady have some idea?
Kind Regards
07-08-2013 12:48 PM
Change it under User --> Edit --> Message Settings --> "Language That callers hear"
HTH, please rate all useful posts!
Chris
07-08-2013 02:12 PM
Thank you Chris
I applied the change that you answer, but the problem goes on, for instnace :
Language That callers hear English --> Sorry(audio english) -- Mario Hernandez (audio english) -- is not available --> this is Correct
Language That callers hear Spanish --> Lo sentimos (audio spanish) -- Mario Hernandez (audio english) -- is not available --> This is Incorrect
07-08-2013 02:17 PM
I sorry, the correct example again
07-08-2013 02:18 PM
So, which one do you want?
If you want the language to be inherited from the caller, then leave the setting as such, keep in mind this only applied to calls originated within Unity Connection and not caller that get sent from CUCM via call forward no answer for example, as those are all inherited from whatever the default it.
HTH,
Chris
07-08-2013 02:49 PM
Ok, the correct funcionality int Unity connection it should be next one:
"Language That callers hear" -- Spanish --> Lo sentimos (audio spanish) -- Mario Hernandez (audio spanish) -- no esta disponible (audio spanish).
This is the way in that others versions of Unity Connection work (for example: 8.5.1ES47.12900-47), and it should be working this version 8.5.1.10000.206.
I have searched for a bug without success.
Kind Regards
07-08-2013 06:06 PM
So, you changed the setting I provided to Spanish? Is Spanish working properly for other things? What version of Locale are you using? Keep in mind in Unity Connection the Locale version needs to match EXACTLY the UCXN software version.
HTH,
Chris
07-09-2013 01:52 PM
Hi Chris
Yes I changed to spanish as you provided, and yes in spanish all the other thing work fine.
let me get the version locale
07-09-2013 03:30 PM
Hi Chris
This is the version locale with CUC version
CUC .- 8.5.1.10000-26
locale .- uc-locale-es_CO-8.5.1.1-16.cop
07-09-2013 07:30 PM
OK, I am little puzzled as to what is not working for you. Can you elaborate on what you are experiencing and what are you expecting?
Chris
07-10-2013 02:30 PM
Hi Chris
This is it that not working:
When a call goes to VoiceMail(Unity Connection), for any extension 4733 of Mario Hernandez, following occurs:
This is the problem, not should work this way
Lo sentimos (audio play in spanish spanish) -- Mario Hernandez (audio play in english) -- no esta disponible (audio play in spanish).
So should work
Lo sentimos (audio play in spanish) -- Mario Hernandez (audio play in spanish) -- no esta disponible (audio play in spanish).
07-10-2013 02:38 PM
What is the "select language" set to under user --> edit --> greetings --> standard greeting?
Chris
07-10-2013 03:00 PM
Spanish(Colombia)
