Issue with CUPC 8.5 PC and CUPC 7.1 MAC
mterruso
We are having an issue which seems to have stumpped even Cisco.
We are running CUP 8.5.2 on the server.
A MAC 7.1 user IM's a PC user using CUPC 8.5 and they receive the message fine.  A reply is sent from the PC user and the MAC 7.1 client never receives it.  This is happening on all of our MAC's not just one account.  If this same person logs on to a PC version they can communicate without an issue.  No firewall or anti-virus software exists on any of the machines.
Presence status updates without issue between the two versions the only thing that seems to not work is IM's sent from the PC version to the MAC version.
Any help or insight would be appreciated.
seongho
This should be a supported scenario.  I have just tested it in Cisco's production network and it worked as expected.  Did you contact Cisco TAC?  They should be able to help you to resolve any potential issues in your environment.  Thank  you.
Seongho Hong
Technical Marketing Engineer
Unified Communications Business Unit
Yes.  TAC case is open.  Just figured I would throw this out there to see if anyone else has seen this.
Hi.. Got a similar bug.. any resolution on your TAC case, seams the 7.1 is very unstable, besides when you use the URI for companny pictures it just crashes. MACs are on MACOS Lion 10.7
Thanks.
