Jabber: Integrating CUCM, Unity Connection and MeetingPlace / WebEx Schedule.
All,
I have installed the Cisco Jabber 9.0.1 Build 8802 on two desktops with Windows 7 Professional / Enterprise and I can use IM with file transfer, but can not make calls, integrating CUCM, Unity Connection and MeetingPlace / WebEx Schedule. Does anyone have any tips or Guide?
Thanks.
Luciane de Medeiros
Jaime Valencia
The jabber guide is available on CCO upon search
Cisco Jabber for Windows Administration Guide
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/jabber/Windows/9_0_1/b_jabber_win_icg.html
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Java,
I even tried to make settings with the Jabber integrations. According to the guide.
IM and Presence work, Authentication in Unity also works, but the registration does not happen in CUCM.
I've tried several settings without success.
The following xml file.
Presence
UDS
Is there any hint or something that can help me?
Thank you!
Luciane
Since there's no troubleshooter here there is nothing else than to look at all the settings.
I had a problem in my lab while deploying this in which my LDAP was not being recognized and had to configure manually the LDAP bind in the jabber config xml, but even with that, I could type in the DN from another phone or jabber client and call it. With that problem I couldn't right click on someone and call.
From what I have seen the reasons for this to happen are always missing steps from the guide, either no CTI GW associated, no CCMCIP profile, failed to associate user/DN/device, wrong group associations on CUCM, etc.
My CUPS/CUCM were already working fine for CUPC and I just followed the guide I sent you step by step to make this work, somethings I had to create/change, a lot was already in place.
java
java
Hi Java.
Thank you, calls and directory are working well.
I needed to associate a Device with the same user and I did it with the IP Communicator.
Now I have doubts about the integration with MeetingPlace / WebEx with MeetingPlace Scheduling. You know if version 9.0.1 build 8802 support this scenario?
Do you have some reference material?
I need to add something to jabber.config.xml?
I have many difficulties in this project.
Thank you!
Luciane de Medeiros
