Highlighted
Beginner
limit max calls
Hi all;
i'm asking if there is a way to limit the maximum number of calls for UC520 to 4 or 5 calls
thanx in advance
Med
2 REPLIES 2
Highlighted
Hall of Fame Cisco Employee
if this is for outbound calls you can use the max-connections command on the dial-peer
java
if this helps, please rate
java
Highlighted
hi,
and thank you for your response, yes i mean simultaneous outbound calls, i'll test this cammand
best regards
Med
Content for Community-Ad
