Maximum sessions with LTI transcoder on CUBE
M02@rt37
hi experts,
I have a question about CUBE LTI transcoding configuration.
When you configure your transcoder you specify the maximum session 《XX》.
This value 《XX》 is calculated and depend on the dsp ressources (which type of PVDM card)? Or is it anything else?
Thanks very much.
Best Regards
Best regards
Jaime Valencia
It depends on the amount of DSP resources, and the codecs to be used in the profile, lower complexity = more sessions, higher complexity = less sessions. If you use universal transcoding, that also takes more resources.
java
if this helps, please rate
Jaime Valencia
java
