Walkthrough Wednesdays
1067
Highlighted
MediaSense hardware issue
By surprise, an error has appeared in MediaSense web admin interface.
Specifically, the message is: "Warning: This hardware configuration is not supported by MediaSense. Only a very limited number of resources will be available. This installation may only be used for demo or lab purposes."
System Version: 11.0.1.10000-103
We are checked hardware requeriment and they are correct.
Is there any log where you can see which requirement is not correct?
Any idea?
Thank in advance.
5 REPLIES 5
Highlighted
Hall of Fame Master
Do you virtual machine settings match one of the following supported specs:
https://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/uc_system/virtualization/virtualization-cisco-mediasense.html#11
Did you install it using proper Cisco OVA?
Highlighted
Hi Chris,
Yes...the virtual machine matches with all spec!
If I remember correctly, I used the correct OVA.
Today, I'm going to try to reinstall the virtual machine.
Highlighted
I also have the same issue... Any luck please let me know
Highlighted
Sorry Mohammed, I had to reinstall the entire server ..
BR.
Pablo
Highlighted
I having the same issue on Cisco Media-Sense but is there any limitation and bad things happening to call recording?
If we ignore that message then any technicality need to consider?
Thanks.
Content for Community-Ad
