Mobility advanatage MCS-7825-H4 installation error
I am getting this error when I am trying to install Mobility advantage 7.0 on MCS-7825-H4
"unable to find any device of the type needed for this installation type"
Everyone's tags (3)
1 REPLY 1
Highlighted
Beginner
I solved it : It was comptability isssue I try to install 7.0(2) on MCS-7825-H4 which is not supported only 7.1(3) that is supported so I used 7.1(3) and i installed it.Thanks
Content for Community-Ad
August's Community Spotlight Awards
