AMA-CUCM Troubleshooting: Best Practices for Reading Trace Files
232
Beginner
multiple users in unity connection to retrieve messages for other users in group.
Hi All,
I have a requirement of setting up a group mailbox ,where a couple of users can retrieve voice messages, however the users all have different extensions. They want to be able to retrieve messages for anyone in the group, it they are called on their personal extensions. They also want MWI notification for messages for other group members. I wanted to find out the best way to go about this. Both CUCM and Unity Connection are version 8.6 (setting up GDM is much straight forward on unity express but I am yet to come across any documentation about this on Unity connection).
I know you can set up alternate extensions with call routing but I am not not sure if this would be adequate given there are about 12 users in each group.
I would appreciate any pointers.
Best Regards,
Y
3 REPLIES 3
Hi.You can create a CTI Route
Hi.
You can create a CTI Route Point with an extension forwarded to Voicemail.
-Associate it to a generic user to create voicemail box.
-add alternate extension to newly create voicemail box.
Configure forwarding rule on users extension to forward calls to the CTI Route Point directory number.
In this case you'll create a single voicemail box accessible from different users.
Carlo
Please rate all helpful posts "The more you help the more you learn"
Highlighted
Beginner
Hi Carlo,How are you my
Hi Carlo,
How are you my friend? Its been a while.I hope you are good.
I run into a hitch when trying to associate it to a generic user(dummy user) as shared line feature is not supported in this build.
Is there a way around this?
Y
Hi my friendI'm fine and hope
Hi my friend
I'm fine and hope you are doing good.
You don't need  to associate that user to a shared extension, but to a CTI route point extension different from Users directory numbers.
Let me know
Cheers
Carlo
Content for Community-Ad
August's Community Spotlight Awards
