07-13-2020 03:09 PM
I am learning CUE with the ISM-SRE-300 in an ISR G2. I am trying to understand which licenses I need once the trial period runs out. The things I want to do are basic voicemail and also the e-mails where the system sends an e-mail with an attached file containing a voicemail message (so that would require SMTP functionality).
I am pretty sure I need the mailbox licenses.
What I'm not sure about are the PORT and IVR-SESS licenses. Do I need those for the above scenario, or just the mailbox licenses? I couldn't get voicemail to work until I activated trial licenses for PORT and IVR-SESS, but that doesn't make any sense to me.
07-13-2020 05:34 PM - edited 07-13-2020 05:55 PM
For voicemail and IVR to work you need to have port license in older CUE versions
latest versions doesn't have a concept of port license only VM and IVR session license.
07-22-2020 11:09 PM
Okay, this is what I get:
kz-vm# show license
Index 0 Feature: VMIVR-VM-MBX
Period left: 5 weeks 0 day
License Type: Evaluation
License State: Active, In Use
License Count: 600 /5
License Priority: Low
Index 1 Feature: VMIVR-PORT
License Count: 60 /2
Index 2 Feature: VMIVR-IVR-SESS
Period left: 5 weeks 5 days
07-23-2020 12:18 AM
VMIVR-VM-MBX:- license for creating the mail box
VMIVR-PORT :- license to create the ports which can be used for mailbox or IVR
VMIVR-IVR-SESS :- License for IVR concurrent session.
The sum of IVR sessions and voicemail sessions shouldn't exceed the number of ports configured.
you can have a look on below link for more information.
https://community.cisco.com/t5/collaboration-voice-and-video/cue-licensing-faq/ta-p/3124290
